Technical  how do you remove the door glass?
Re: how do you get the door glass out?
Hmmm, wish I could remember, just stripped a door a few weeks back. I just kept unscrewing things and eventually it freed up but the winder mech looks a pig to get back in again. How far are you dismantling?
The glass is held on the regulator by a plastic clip, tags on the clip expand once it's pushed through the hole in the glass.
The best way to separate them is to take the glass and reg. out as one unit, then you can easily push the tags in to separate the two.
you are both right, however the mk1/marbella doors are a little different from the mk2.
these are mk2 so i did not have the two 10mm bolts. where as the marbella/mk1 doors have that. which i think is a bit of a better design.
i have taken some pictures that i am trying to get off my phone and put on to here...
