Hey WNWL
Take a look at
https://www.fiatforum.com/showthread.php?t=45689, where I posted some stuff on how to remove it.
Basically, to clarify, for the rear doors do this:
1. Remove the cap where the electric window switch would go (small flat bladed screwdriver), at the top of the grab handle, and remove the Allen Bolt.
2. Remove the cap behind the door handle (careful not to scratch the door trim!, use a small flatbladed screwdriver again), and remove the Allen Bolt.
3. Remove the Allen Bolt from underneath the grab handle.
4. Pull off the window winder handle (hold the base and give it a sharp pull), and remove the circular surround from the door trim (make sure the spring clip is still in the handle!).
5. Undo the 3 screws at the bottom of the door trim.
6. There are door poppers on the side of the B and C pillars; I used to pull it from the bottom and work my way up.
7. Once all is loose, push the trim upwards to remove the top seal from the door; be careful not to crack the actual door trim though!
8. Once removed, unclip the door handle link rod from its seating clip (brass knuckle), then rotate the white clip on the back of the door handle to free the rod from the handle itself.
9. Undo the speaker connector and remove the trim!
Do remember to re-seat the brass knuckle back in the black clip for the handle rod; I forgot to once, and of course the handle pulls the cable, but nothing was stopping the outer core from moving so the door wouldn't open!
Hope that helps!
