General how do you remove air filter housing on 500L 1.3 diesel
davehodgson
scunthorpe
Hi I have a 500L 1.3 multijet diesel 2013 model. It is leaking diesel and appears to be coming from the injector inlets. I cannot get access to the injectors as the air filter housing is in the way and I can't work out how to remove it to allow access. Can anyone help please
Not something often covered on here.
Look .. SEARCH..in grande punto section..
I THINK it may just be on rubber studs.
Do let us know.. PICS would be great
Have a look at this also
http://62.106.11.160:8000/navi?SGRP_COD=23&COMM_MODEL=CINL&SBMK=F&COUNTRY=99&DRIVE=S&MVS=33017R051870&MAKE=F&CAT_COD=73&GRP_COD=102&SGS_COD=10223-010&LANGUAGE=3&ALL_FIG=0&NEW_HTTP=TRUE&SEARCH_TYPE=codpart&RMODE=DEFAULT&KEY=PARTDRAWDATA&EPER_CAT=SP&GUI_LANG=3&ALL_LIST_PART=1&PRINT_MODE=0&PREVIOUS_KEY=SUBGROUP_7&SB_CODE=-1&WINDOW_ID=1&ALL_LIST_PART=0
Pics of housing.. no holes or screws.. visible
If it's like the one on the 500
Remove the air intake pipe and then the pipe going to the turbo both on bottom half of cover then pull the whole cover up as it's on rubber bungs
Becarefull where you pull as the corner tend to flex a lot and you can crack the cover
