How do you change interior lights?
  • Thread starter J
  • Start date
  • Replies 5
  • Views 381
J
J
How do you remove the covers etc to get access to the interior bulb lights as I am going to change them to LED ones.
it's easy peasy to do... there are a couple of clips that hide the screws... unclip them, then unscrew... then unclip the electrical connection thingy. then there is a key like thing that you pull off and a flap, then you can see the bulbs... it's pretty straight forward... once you undo the screws you will be able to see for yourself
What type of bulbs are they ?? (ie 239 / 264) I don't know where to look :~)
There will only be a key if you have an electric sunroof.
By the way what's the advatage of LEDs? If they are brighter I might be interested as the light covers on my Brava block out quite a lot of light from the 2 bulbs.
Would Halfords have them? Cost?
Gerry
Edinburgh
They are "Festoon" type bulbs. The reason I am going to change them is that they are brighter and they use less energy so with my dodgy interior light switch if I leave it on accidentally the theory is it won't drain all my battery!
J
837
J
P
15
13K
Dark Lurker
J
532
J
