http://cgi.ebay.co.uk/15BHP-Power-Mod-Chip-Fiat-Coupe-Turbo-Punto-Uno-Tipo_W0QQitemZ350160373155QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item350160373155&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
"It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold and so advances the ignition by up to 2 degrees with more fuelling to compensate, therefore producing more power. In many cases fuel economy is increased too. Power is increased by up to 15BHP and torque is increased significantly.
It will be more responsive and you WILL LIKE IT."
Another one here: http://cgi.ebay.co.uk/FIAT-ECU-CHIP...14&_trkparms=72:1683|66:2|65:12|39:1|240:1318
"How does it work? The mod itself is a small resistor that tells your engine control unit (ECU) that all of the air coming into the engine is cooler (and therefore denser) and packed with oxygen. The ECU then sends this a signal to the fuel injectors which, in turn, creates a more powerful detonation in the combustion chamber."
Oh I see! It makes more powerful explosions in the engine than the car should usually have....
Huh what?
Huh what?
