Technical how do i test relays?
Your drawing is too small to read I'm afraid.
If you put a feed through the coil to earth, so one side feed, other side earth, the relay should click. A feed to one of the other connectors while the coil is energised should produce power at the last connector.
Looking at your drawing:
when the relay is not energised, you should have continuity between 3 and 4. No continuity between 3 and 5.
when you energise the relay (12v feed to 1 and earth to 2), it should click and you should have continuity between 3 and 5. This time, no continuity between 3 and 4.
Also make sure you never have continuity between 4 and 5.
Basically, you are flicking a switch that goes from 3 to either 4 or 5, by energising or not 1 and 2.
