General How do I bleed the cooling system on my ducato 2.5tdi
Gumdrop
South Somerset
Hi all,
Having heater problems on our Ducato 2.5tdi the bottom rad hose doesn't get hot which indicates thermostat probs its sosay had a new stat fitted can they be fitted incorrectly.
What is the best way to bleed the system? Anyone know.
Cheers Gumdrop
The bleed valve should be at the highest point in the system, so look at the pipes around the top or above the engine, if you can't find it, the next best thing is to disconnect a pipe at the top of the radiator (smallest possable).
