john55
Established member
I have a Stilo Multiwaon with the usual ABS ASR error coming up all the time.
I have read many posts on here about fixing it. Replacing the battery, even modifying the wiring so the ECU thinks the air-con is on. None of these address the real problem and only fix it temporarily. As cars dont usually have this problem from new and it develops over time and is worse when cold/ damp, I beleive there are 3 possible causes, or probably more likely a combination of the three.
1. Corosion or poor connection somewhere in the wiring
2. Bad layout of the wiring loom in the car
3. A fault with the ABS pump itself
As an electronics engineer, with quite a lot of experience working on cars (my latest was an Audi A8, where I saved the owner over £4K compared with what Audi would have charged to fix it. There are 49 computers and many Km of wiring in that car, but I managed to fix it and even educate an audi technician on how to fault find quickly on them).
Although I am new to Stilo's, I am learning fast (as things fail on my car) and I intend to systematically go through the ABS system and see if I cant solve this once and for all.
What I need is help from you guys, in the form of, wiring diagrams/ pinout for the ABS pump/ system/ ignition wiring in the cars.
Also has anyone else had a serious go at fixing this, and have found things which work/ dont work.
I want to start this weekend, so please post soon.
Thanks.
Thanks.
