Invisible Man
- Joined
- Mar 8, 2016
- Messages
- 14
- Points
- 5
First of all just a quick Hi. I'm Shaun and I'm a new member and also the new owner of a 2002 Fiat Sie 1.1 S.
I picked the car up yesterday for £380 as a second car for the family; my GFs just passed her test and has borrowed/ stolen my ageing Corsa C. I used to own a Fiat Cento which i inherited off my sister as my first car. I loved the car and maintained it religiously but unfortunately it sucumb to rust and was traded in for my Corsa C. While the Corsa C feels a lot more refined it just isn't as fun as the little Fiats.
Back to the Sei. I did the usual checks when i bought it. Cream in the oil filler cap, oil in the water, checked for rust and it looked clean and honest. Took it for a test drive and it selected all gears, clutch worked fine (was replaced 10k ago).
This is where i could use some advice:
Driving it home i noticed a couple of problems:
-Brake Squeal. Front LH brake squeals intermittently. I'm hoping dirt or possible new pads required?
-Gear lever feels kind of sloppy ie like there's lots of slack in it. I can select all gears fine.
-When accelerating there's a very very faint rubbing noise from the front LH. When the accelerate is released slightly the noise disappeared.....I seem to remember my Cento did the same? Maybe.
-First gear grinds ever so slightly when selecting and Reverse is sometimes hard to get.
When i got it home i noticed:
-Rocker cover gasket is leaking oil. Looks like someone has tried to seal it at some point. Looks like simply a new gasket?
I intend to change oil, Coolant and filters as a matter of course. Is there anything else i should check/ change?
It has been suggested that the HG be replaced as a matter of course before it goes and damages the head. Is this good practice or a waste of time?
Other than that the cars OK and for £380 its almost disposable.....However i would like to see how many miles i can keep her running for! 200K could be doable!
Sorry for all the questions,
Shaun.
Shaun.
