Hello,
Could try replacing your fuel filter....
Purchased a second hand, 55,000 mile, 56 plate Sedici with the 1.9 Multijet engine that suffered hesitating at just below 1900 rpm and poor pickup from a stand still.... took this as turbo lag after reading similar threads and suggestions about the EGR being the problem. (checked mine and noted a brand new one fitted). Previous owner obviously had the same problem then gave up and part exchanged the car.
A week after buying the car it broke down! It started and idled rough but then shut down by engine management safe mode. Garage recovered and traced fault to an injector. Thank god for the warranty! Injector was replaced and car performed like new. Couldnt understand why an injector should fail after 55,000 miles!!! Few miles later the hesitating slowly returned!
Decided to change fuel filter by myself....
Bingo... old filter cartridge was made from a fabric material. Have replaced with a 'Fram' paper aftermarket type for £10. Think it had been shedding strands of fibres and sending them to the injectors and clogging them! (have binned the old filter but think it was made by 'Blue' filters... when i ran my fingernail over the surface, fibres would loosen and detach!)
Cars service history shows filter was replaced previously at approx 30,000 miles by garage!!!
Could also be fuel starvation due to the filter being clogged??
Hesitating is cured. Car has stopped kangarooing and pulls away without the need for high revs. Hope this helps to all.
Please post reply to possibly help other Sedici, SX4 and Multijet users.
