Technical Help!!!
Technical Help!!!
Just to make sure you are aware but the NS caliper has a left hand thread to wind back the piston not right hand thread like the OS
Please send cheque to
NumanR,
C/O The Fiat Home for the Permanently Bewildered Technician,
Bath Road
Slough.
PS Decky, the thread is there for the handbrake mechanism self adjustment, you have to wind the pistons in when replacing the pads.
<the thread is there for the handbrake mechanism self adjustment, you have to wind the pistons in when replacing the pads.>
Right, thanks. I'm still a little confused though.
If the front caliper pistons are self adjusting then why aren't the rear?
Why different handed threads?
Don't some cars have threaded caliper pistons on the front?
Been puzzling me for ages so any information gratefully received
Sorry, just naturally curious. Pysch tried drugs but only made him worse
The handbrake mechanism on vehicles with disc brakes on the rear, and actually use the service pads as a handbrake, need a self adjusting mechanism, to maintain the handbrake travel at a near constant level. Because the hydraulic brake caliper has no mechanical operation to push the pads out, when you add the handbrake mechanism it has to operate the rear of the pistons and so a self adjusting thread is used as an ajuster. To push the pistons in you need to deajust the mechanism and wind the pistons in. Different threads due to the different sides of the vehicle, it could be for identification, but on later fiats the NS piston is left hand thread.
Great. Thanks for that:)
As I'm bound to need to do the job some time or another I would have thought opening the rear discs bleed nipple and dumping the brake fluid out would help in pushing the pistons back in and also prevent contaminated oil being pushed back up into the system.
I would have thought it's best to use a dedicated brake caliper retracting tool which rotates the piston whilst retracting. Whaddya think?
