i need some help geting windows7 of my computer. the windows7 i got has run out and iv had to download vista iv got the vista up and runnng now i need some help on get 7 of i dont have a clue how to do it
dont no how can i find out? and how would i format itHave you got two partitions or hard drives? If you have then just format the partition or hard drive Windows 7 is on.
yaAre you getting a boot menu when you turn the PC on, asking whether you want to boot Vista or 7?
You need to have a bootable disc of Vista, then restart the computer and boot from the disc (press any key at boot from disc prompt), during setup you can delete your old partition or format it so the drive is blank, if you delete the partition you will make a new one using the whole space. You might have to change the BIOS settings to allow you to boot from a disc first
Bear in mind deleting the partition or formatting it will remove all data so back things up first.
To see if you have two partitions look in my computer for the logical hard drives, if there is two but you only have one physical drive it's partioned into two, but I don't think it would in a favourable way to allow you to format one.
hard dick drives 2Have you got two hard drives showing in My Computer on Vista?
£100Quite easy really, You got to PC world or an online retailer. You pay roughly £100 and you get this amazing thing in return called a Bootable DVD which Windows on it.
You then put the DVD in your drive and boot off it and follow the numpty wizard.
£100**** of. i had vista on the computer when i got it and then i let my bellend brother near it and he fort it would be agood idea to download some windows7 testing thing:bang:
iv got a product key is that is that itIf you have a legit OEM key on the side of your case download a Vista OEM Iso and burn it to a disk. Make sure you install the version your key is for (I.E Business, Ultimate etc etc).
