Technical Help!!!!!!!!!!!
whipsy
WHITWICK
MY FIAT BRAVA 1.2 HAS STARTED REVVING ITSELF, IVE CHANGED THE MAP SENSOR AND THE STEPPER VALVE WITH NO LUCK, DIAGNOSTICS COME UP WITH THE MAP SENSOR OBVIOUSLY IT WASNT THAT. ANY SUGESTIONS WOULD BE GREAT.:bang:
NO NEED TO SHOUT
Is this only at idle, or when you're driving?
if it is at idle, i would confidently say it is the ICV [idle control valve]. You can either clean it or replace it but make sure you don't adjust it.
