Help!!
Help!!
Moesie
Hi, can someone please help me locate a spare part from my Fiat Bravo 16v 1.6 car.
I took my car into my local garage, as it was leaking some fluid under the bonnet. The garage told me that the car needs a new 'fuel rail injector - end clip'. The Fiat garage said you cannot buy the clip on its own, you would need to buy the whole unit at £260 + VAT! :yuck:
I've attached a image of the part I need, but I have no idea where to start looking. Please help :(. Many thanks.
Thanks Trevor, as you can probably tell from the pictures the current clip has got two of its hooks broken. But I think the 1.2 engine should be okay.
Many thanks again.
Hi again, got a look thismorning, looks similar? the only problem is, it looks like the whole inlet manifold need off to get at it? so allthough the parts not worth much, it's a fair bit off work to get at it? if you want to pm me with what you think it would be worth to you?
Cheers Trevor.
