rallyman1984
Hello Fellow Fiat Forumer's
I've been helping a close friend try and sort his 2017 Fiat Ducato 2.3 JTD SWB Van out. (113,000 miles)
During the cold snap, it wouldn't start until it was well above 5'c.
He said it was glow plugs, and hence 4 new NGK glow plugs went in, despite me telling him they all checked out (as did the diagnostic machine) Ok.
anyway, Done a leak off test, and it needed injectors, 2 really bad, 1 ok, and 1 good. So stuck 4 in it, and now it starts as it should with minimal cranking.
THE remaining problem. (which its always done, even before the injectors/non starting in the cold)
Under FULL heavy throttle (really really loaded, or towing) , it lets a sudden "jerk" which it throws itself into limp mode, and then engine light and a massive lack of power.
The only code keeps coming back when it does this is "P023761 - Turbocharger Control Negative Drift (High Pressure) - Signal Calculation failure."
I've checked the vacuum hoses, all look spot on (haven't been as far as the actuator yet tho) all look ok.
boost pipes all look good and doesn't appear to be any splits etc.
it goes like **** off a shovel, as apparently its been mapped and EGR mapped out (unsure if its blanked or not) by previous owner(s)
Could it be a chafed wire ? Map Sensor ? Boost Solenoid ?
seen loads online of underboost faults but not found any overboost faults.
any help, pointers or "id check this" would be greatly appreciated as its a cracking van, but such an annoying niggling problem.
