Help with my stilo 1.9 td
clarefarra06
Loss of power in low gears?????? Stilo 1.9 jtd
Pls help me... I'm blonde lol... Have had car since new 03 no major problems but the last few weeks loss of power in low gears!! Also chucks out black smoke when reved??? I have been ripped off too many times now! Also have sky roof which does not open at all.. Is this expensive to repair? Cheers peeps x
Blonde, you say??? ;)
Try posting your query in the Stilo-specific section: https://www.fiatforum.com/stilo/
There are always loads of knowledgeable people viewing that section, and if an answer to your problem exists you'll find it in there.
Also try using the search function as your problem is probably quite common and has most likely been asked and answered several times in the past.
I'm no expert but I'd be thinking of (in no specific order):
1, EGR valve fault
2, MAP sensor fault
3, Throttle body (build up of filth).
Good luck, and welcome to the forum :)
