HELP with my clutch
HELP with my clutch
A
Alan H
Hi all,
there have been a few people on here had problems with their clutches i believe. after getting it changed the car judders. about a month back someone suggested it was either
a. out of balance OR
b. trust bearing was in wrong
is there any other possibilities and is it possible to have this fixed without having to buy a new clutch?
Any help appreciated
if it was me mate id just get a new one for what its worth, and at least then if there was a problem with the clutch you dont have to worry about making incorrect assumptions and forking out £ after £.
Neither of those will cause it to judder, certainly a clutch can never be out of ballance unless something breaks or falls off and then juddering will be the least of your problems.
iirc, this was brought up before, and i have the same juddering problem, only when the engine is cold though, apparantly its quite a common problem with a bravo
ryan
so is this problem fixable in anywya or does it require a whole new clutch to be sorted?
