Technical Help with messurements 500
Visby, Gotland
Hi guys,
While I wait for my restoration thread to start working, I need som help from you that have a 500 close by. As same of you know, I´m currently rebuilding the front end of my 500F, "Raukstern´s 500F -65 rebuild"
The messurements I need are the ones shown in the pictures below:
1. From the bracket holding the tank to the edge of the floor above the battery.
2. Between the indentations on the "floor"
3. Between the outer side of the inner wheelhousings and between the whwwlhousing along the "floor" och the trunk/boot.
If I could get it in millimeters it would be lovely. Otherwise I´ll find some way to translate it.
This is all ti help me get the boot floor positioned right.
Thanks /Seb
Let me see what i can do..
Your lucky i haven't cut mine out yet lol.
I think you only need the tank bracket edge to the edge of the plate as in photo 2.. Everything else will end up lining up to what it ends up being.. The reproduction parts do not have the indents always in the same location as the original.
As far as your 3rd request.. are you looking for the distance of the upper wheel arch tabs?.... hard to explain.. the pcs free floating in your 3rd photo..
anyways, ill snap up some pics for you from mine.
My front tubs/sheet metal is still original with the exception of the front headlight/body panel.
If you can upload a photo with the exact points you need a measurment i could help.
Heres my 2nd guestimation of what you were looking for. 103.6cm for the support strap.
