GhostSpider
- Joined
- Mar 2, 2015
- Messages
- 5
- Points
- 2
Hope You could help me with this matter.
I'm constantly getting an ESP fail & ASR -failure while starting the car. ( No ABS -failure )
Car it self starts very well and runs like a charm but those faults keep blinking...
Fault codes which car is given are:
- C1101 CAN -error (NAC)
- C1117 Steering angle sensor
I've been spending hours and hours searching the fix from internet but no success.
-New battery
-Cleaned the fuse-box and all the fuses
-Cleaned D4-connector
-Checking out and cleaning the brake switch and it seems to be working ( brake lights work OK )
I also found some comments that this ESP & ASR-failure can be caused because of some problems with Air Condition...but this sounds weird??
I found that some one had this problem fixed by adding more "liquid" to AC but for me... like told before ...weird.
Any other ideas where to find the fix??
How can I calibrate or change the steering angle sensor and where is it?
Can this cause also the ASR & ESP-failure?
Could this be caused of fault ABS-sensor and how to solve is it rear or front and right or left ?
-New battery
