Technical Help with alarm wiring Ducato 2022 / GPS-303 GPS tracker
Cresser
UK
I have a GPS-303 GPS tracker and I am trying to workout how I can connect it into the OEM alarm.
The GPS-303 has a positive trigger wire that when triggered will send an SMS message. Ideally I would like to see if I can connect the wire to the current OEM alarm system so when the alarm goes off I would get a text.
Does anyone have a alarm wire diagram for a Ducato 2022? Or any idea where else I could connect the trigger wire to? I was wondering if the siren positive wire would be an option?
I'm afraid that such things will be hard to find online. For security reasons. Another thing - I wouldn't post online this kind of information - there are GPS + GSM jammers available cheap as chips, so thieves will eventually know to bring one with them when going to get your van :)
Logically I'd try to use for example the signal used to trigger the siren. If triggered with positive signal.
Well I see security as multi layered for example deadbolts, External door shielding, steering lock, obd2 lock and GPS tracker. So if they get through all of that they probably deserve the van.
The siren trigger was what I was thinking. If or when I get around to it ill post the solution here.
Thanks for the reply x
