Hi, I'm having some problems with Ducato 2015, 2.3 130 Multijet.
The first problem is engine jerking when changing gears. Changed bad engine mount but issue still persists, though it jerks less, but still too much, even in lower gears like from 3rd to 4th. Is that acceptable, does it happen for all Ducatos, or is it a problem? Maybe it is related with the problem below?
The second and the biggest problem is rough engine work. Most often it happens when starting cold.
1. Throws a lot of white smoke with strong diesel smell. Clears up in few minutes.
2. Feels like struggling on idle. Similar feeling like idle hunting, but RPMs are constant and do not flactuate. Starts working normally in few minutes.
3. When accelerating and changing gears from 1st to 2nd, RPMs drops very slowly. Need to wait a second or two to release clutch since RPMs are too high for the next gear.
4. When driving and depressing the clutch, for example coming to a stop, RPMs drop down to idle RPMs (~900) and then jumps up to like ~1200 and then back to regular idle RPMs.
Sometimes no symptoms appear, and sometimes few of them appears at once.
No power loss whatsoever. No engine light. Connected to body computer and no errors were found which could be related to these issues. Went to garage, they couldn't find anything.
Any ideas?
Any ideas?
