General HELP where do they go?
wofyofs
London
:bang: Can any one tell me which HT leads go where on my distributor cap as silly husband took them off without marking them first?:bang:
If you look closely, you should find there are numbers near the base of where the leads connect. I suppose there's a chance that aftermarket caps may not have the numbers, but it's worth a look with a torch. Sorry I don't have a cap handy, but can probably get one if you're still stuck tomorrow?
The cylinders are numbered from the cambelt (driver's side) end of the engine.
-Alex
on your distrubutor cap no 1 should be marked on the cap itself. as your firing order on this engine is 1,3,4,2. place your plug wiring clocswise on your distrubutor cap. no1 sits at the cambelt side of the engine when you plug them into the engine.hope this pic helps
