Georgpap85
- Joined
- Mar 29, 2016
- Messages
- 2
- Points
- 1
I bought a fiat stilo 1.6/ 2003 model, two months ago, when I bought it the car wouldn't idle properly, and the problem was becoming worse when hot.. I get to a garage to get the throttle cleaned. after the cleaning it was ok but check engine light came on occasionally and throttle died. when switching off the car and on again it was fine. I went back to garage and they said that it was a throttle error message and that I was going to need a new throttle if the problem persisted. Well I left it as it was, but now the weather became hotter and the problem became worse... I read a few threats here and read about the throttle relearn procedure, I tried to do the throttle relearn, but when the cooling fan supposed to cut in, something strange happened. The throttle died and the car rev went about 1500~2000 rpm, as it does when it does the problem, I left it a few more minutes but the cooling fan never turned on. So I started to notice that the problem with the throttle comes when the car it is supposed to turn on the cooling fan, e.g when in traffic and it is hot outside, and I could notice it now because the weather got more hot and the problem started to come on almost on every day when the car is hot and I am in traffic. Cooling fan never goes on!!! I wantted to get sure if the problem is related so I repeated the test, with the engine running and with the car stopped the thottle dies and car revs goes 1500~2000 every time car reaches 90C and the cooling fan is supposed to turn on. I also noticed that when switching off and on again a red dot at the temp reading comes on, displaying high temp? for a few seconds, but cooling fan does not come on. Before the throttle cleaning the car had idle issues but never engine fault. Also I remember a few times that the cooling fan did turn on before the throttle cleaning. I hadn't connected the throttle problem before because the weather was more cold and I also use to drive more on the highway, I also need to mention that the problem never happens on the highway when the car runs fast and it doesen't get hot. It always happens with the car on traffic or stopped. Please any help or suggestions where to look would help. Could it be a bad ECU? and how can I know for sure? I have the car for two months and almost want to give it away really cheap just to get rid of it and it will be a pitty because I will loose both a lot of money and time... Thank you a lot!
