- Joined
- May 10, 2010
- Messages
- 2,669
- Points
- 801
Just goes to show that air can leak in through a small gap but diesel won't necessarily leak when under pressure.
The leak's on the low pressure side. so before the hp pump.
Just think of it as sucking up fluid through a straw with a small hole half way up it, the fluid won't leak out, but you'll get a mouth full of fluid and air.
Now if you cover the end and blow fluid out through the same straw (high pressure side after the hp pump) fluid will leak out of the small hole.
Leaks on the low pressure side tend to draw air in, leaks on high pressure side tend to leak fuel out but both can cause low fuel rail pressure.
