just thought id let you no what happened, the wires to coil pack had all burnt out, and a new wiring loom was fited from a scrapper , ive replaced battery , and the car ran fine , she then failed her mot on emisions, i wasnt surprised as it was still not running 100%. i checked the timing and adjusted it , which made her run perfect and then she passed her mot.
after all that , a week later , the rediator expansion tank cracked when the mrs was on her way to work :S and guess what , another head gasket!
i had the head tested and refaced, and a new expansion tank.
i managed to o remove the head in 1.5 hours , and bolted her back together again in just under 2.5, i thought that was pretty good going for a novice like.
thanks for all your help guys.
gaz
