Technical  Help please!!
Smithy783
Hi guys, my grande punto active sport 2007 would not start this morning..
Alll electrics are fine but the car doesnt even make a sound when I turn the key. The car protection system fault (fiat code) light is on and I only have theone key, any ideas on how to solve issue please guys?
It's happened to mine twice flat battery mate needs a bump
sounds most likely, (y)
if you can get access to a test meter;
the battery should have @ 12 volts when engine + lights off,
once the engine is running it should read @ 14 volts,
if less than 13.2Volts with engine running .. you've got a charging issue,
worth doing this before buying a battery you don't need, ;)
Charlie
