Technical Help please!!
Yazza54
Established member
Manchester
So I made a new CD this morning for the drive to work and what not. Puts it in the multichanger and selected CD3 and it didn't play. So i thought fair enough it sometimes does this. So I tried to select a different CD and it wouldnt change. Now it just says CD3 PAUSED ... and if i press pause it says Check CD....which would be fine except it won't let me change to a different CD nor will it eject the one theres a problem with. So it's basically just frozen on CD3 now and won't function otherwise.
What do i dooooo?!:mad:
Maybe try to disconnect the power to the changer then re-connect an hour later :confused:
I did the same on my wifes old Honda and it worked once..... but the next time it played up I had to take the cursed autochanger apart to get the cartridge out :(
Hmm I was wondering if it could be a fuse but it seemed to have a problem with the CD first before it just decided to not respond.
Anyone had a similar problem??
