S
shellyhul
there is problen with the car i was driving all all of a sudden it will not allow me to change gear ... it is not the cluth cylinder thing that pushes cluth i can see it working fine. the only way to move the car is turn it off then select first gear and start up with clutch pressed in gear .. then as i drive force into second .. and third .. i managed to make it home this way.
there is plenty of fluid in res and no leak.
and when started in gear the clutch is working as it stops the gears engaging .
