Technical help needed glasgow or lanarkshire area "help needed Bravo 1.2 making funny noises"
john84
hi im john and new in here only few days i have a fiat bravo1.2sx 51 model and had it in garage thought it was ignition coils but it aint , garage says he cant look at it as he not got tools for fiat , thinks it maybe engine problem , can anyone help me im lookin for somewhere near me to help get it fixed
mountainmachine
Bravo 155 HGT
Ayr, Scotland
Re: help needed glasgow or lanarkshire area
hi m8 , i hope u dont mind me gettin in touch with you but lui in the forum said you may be able to recommend someone , i have fiat bravo 1.2sx 51 model and had some probs with it had new clutch is fine now and now when accelaratin it makin a awful noise , had it in garage of a friend and he says maybe engine prob but as he not fiat he cant look at it , can u help m8 thanks in advance
Hi mate, best if i reply here then it may help someone else or someone will see it who knows more than me!
I'm not sure of a garage in the glasgow area, there's a decent fiat garage down near me, but i'm down at Ayr, not sure of anywhere in Glasgow.
On the 1.2 there's not much a normal mechanic couldnt do to investigate a noise etc. I take it your engine management light isnt on or anything. Only specialist tools needed would be for some of the diagnosis (engine management based) although should be OBD compatible on a 51 plate and for setting the timing.
Is it running at the moment, can you describe the noise. What work have you had done on it of late?
Also i would duplicate this thread on http://www.fiat-scotland.com/phpBB3/index.php not as technically minded but someone may be able to recommend a garage.
mountainmachine
Bravo 155 HGT
Ayr, Scotland
Ps if you find you need to swap out bits to investigate the problem, i'm down nr Ayr and have a 1.2 sitting doing nothing.
custard
Status: DEFCON Grumpy
Edinburgh
what probelsm is it your having?
OP
OP
J
john84
hi guys thanks so much for your quick replies , i appreciatte them
i have had new clutch done and it was fine .
when i accelarate there is an noise , not whining but a kind of ( cant describe it sh**) as if im accelarating to 90mph but only got my foot on the pedal just .
had it in arnorld clark garage where my brother (as a labourer)works and they changed ignition coils and so , but stil same noise , he said it maybe somethin to do with the engine,( a valve or something, im waitin him call me bck to ee what he thinks , he is a good guy and not charged me for any of this work he done , clutch he took 40 pounds for as i know him well) the car can start and will run but he says i might feck up the catalytic converter if i drive it
thanks john84
mountainmachine
Bravo 155 HGT
Ayr, Scotland
thanks john84
If it was a damaged valve then a compression test should show it up.
As for the noise does it sound screechy, clunky, rumbley?
OP
OP
J
john84
it sounds kind of (racing) mountain m8 if that any good to you , no grinding or crunchin , sounds like it comes from alternator area but im no good with cars m8 honestly ,
u say u have a 1.2 sitting doin nothin , are u any good with cars as i wouldnt know how to swap a screw for a screw m8 , i would gladly pay you for your time if i can manage to get car down your way, and would you know how much it is roughly to put it into fiat for them to diagnose m8 ,
thanks again for your help
john84
mountainmachine
Bravo 155 HGT
Ayr, Scotland
I'm not a whiz, know the basics, have a friend who helps me big time, however he's really really busy just now.
I'd take it to a fiat garage, get them to diagnose and give you a price to fix. It will depend on how long it takes them to diagnose, some might do it for £40 if it only takes and hr.
Then if its gona be mega expensive you can always think about using 2nd hand parts etc.
jug
blessed are the apostates
Durham
Re: help needed glasgow or lanarkshire area "help needed Bravo 1.2 making funny nois
if they changed the coilpack then they must think it is misfiring, is the noise the only symptom or do you have an erratic idle and rough running and power loss as well?
roughtly how many miles after the clutch change did this start happening?
OP
OP
J
john84
yes jugs , only misfiring and the clutch is good my m8 inarnold clark had it in and he thinks it a misfire , guy near me gonna put it ondiagnostic for 40 pounds on saturdy and i see from there
cheers john84
jug
Durham
do a compression test, head gasket problems often cause this on the 1.2.
OP
OP
J
john84
got it all fixed guys, was a dodgy ht lead no 3 i think and new plugs done it , guy in cambuslang put it on lappy and got it done , feckin brill
cheers john84
prestige decodes in cambuslang are ace and took pennies only
OP
OP
J
john84
hi mountain, yea m8 that is the guys , 100% spot on they were and all genuine , cost me £55 for new spark plugs ,and new ht leads, diagnosis on the laptop and all, took them about 45 mins to check it out but they checked everythin from alternator to coils to compression and all that .
cheers john84
alainax
α ψΨψ Ω
lanarkshire
i just live down the road from cambuslang, must admit ive never heard of em :eek:
mountainmachine
Bravo 155 HGT
Ayr, Scotland
£55? what spark plugs were thay? i've got denso iridium in my 1.2 and thay were £60
cost me £55 for new spark plugs ,and new ht leads, diagnosis on the laptop and all, took them about 45 mins to check it out but they checked everythin from alternator to coils to compression and all that.
Ohh mate you were ripped off at £60 for 4 spark plugs, i got 5 for a 1/3 of that, and yes Iridium ones.
OP
OP
J
john84
cheers mountain for highlighting what i had done for the price, i thought it was excellent and im sure it is , i believe it can cost 40 pounds just to diagnose on lappy , the guys are genuine and i will go to them again
cheers john84
mountainmachine
Bravo 155 HGT
Ayr, Scotland
cheers john84
Yup good price. (y)
