Hello Peeps,
Bought an 02 Punto last year (Mk2 sporting), ran like a dream, then head casket went. Got a new one done, £450.
Drove it away, but revved to high when idle. Small problem really i'd been driving it everywhere, took to another garage as original mechanic has gone, told me head had gone. Didn't beleive them. went to pick it up from a Fiat specialist that they had passed job on to - car was a wreck.
I believe it sounded as though firing on two cyclinders ie ECU/coil problem but at this time hadn't done any research so took back to the second garage. After 4 weeks of them playing with it bought a new engine from yard. Saw yard car, it was a write- off. Engine only done 27k so bought for £380 and let second garage fit it.
Now they tell me that the new engine needs a new ecu and keys barrel etc. (Fiat dealers Cambridge)
Looked on this great site and found info on how to change coils. Bought a pair and put on. Not much difference. Called AA-fault codes for fuel sensor came on only (P0460) but told this would not affect engine, this code was just for the display on dashboard hence allways showing low.
Now, I have the original ECU in car. Runs like 5hit but does start and stay running but only on two cylinders so no good obviously.
I have a new ECU I believe the second garage ordered but I think they tried this one without using the phonic wheel learn, could this have made it unusable or could this technique still be applied? Tried it but when I try to start it and push on gas does nothing unlike original ECU, so put original back in.
Also by using new ECU and my original 'probably' faulty ECU could I have damaged the new coils (only been in there for an hour)?
I have spent £1100 trying to get it sorted and it is worse than when I first brought it in, even with a new engine, but I am sure the problem is technical not mechanical.
I have lost my faith in Fiat dealers as all the official Fiat dealers tell me the same thing - to buy new parts as it 'MIGHT' fix it!!! - they told me that £1100's ago.
So I am going to give it a go myself and would really appreciate some advice.
Also one of you members with 55 thousand posts says an 02 MK2 Punto does not need now keys for a new ECU, but with a new engine is this MANDATORY? It still starts with my old key and sounds no different to what it did with the old engine I had the head done on. I think the garage thought a new engine would make things easier so they lied and said I needed one, hence not charging me any labour!
Please fellow Puntoians, don't let me lose faith
PS I don't know much about cars but am starting to learn so if I don't make sense my apologies
