Technical help in decoding trouble codes
alucinatick
Lisbon
hi all fiatistas.
so my mk 2 has some issues ,the most annoying one is the steering light on.
i have made a diagnostic and came up with some trouble codes.
can u please help me out in figuring wath can i do to fix them.
i have attached the report from mes for you guys to see.
thanks in advance.
  • relatorio erros.pdf
C1015 - Control Unit Fault (Internal Fault) from my experience is usually the true fault, as you complain about steering and computer complains about (internal) control unit fault. And usually doesn't matter how much you check everything it comes to the conclusion that the Control Unit is at fualt.
The C1006 - Steering position Sensor could be the follow up fault from the internal fault.
I'd make the internet search about those faults (maybe someone had the same problem and fixed it by lets say, replacing the control unit)
But in my opinion of what I have heard and seen, the motor is at fault as its the control unit as well.
