Hello forum friends,
It's summer starting season, and my usually reliable Fiat 126 is giving me starting problems after sitting idle for 6 months (which it does every year, usually with no issue!).
I only had a few hours and a single pair of hands the other day but couldn't get to the bottom of it before having to give up until next weekend where I am hoping to return with my glamorous assistant (girlfriend). I was hoping more experienced members could help me narrow down what to try.
Here are some facts, first of all:
Any help or suggested steps to speed up diagnosis would be greatly appreciated.
- It's nearly definitely not a battery issue. The first fix I attempted was to top up the battery and even to start with a jump start device. No difference to the outcome.
- There is sufficient fuel in the vehicle and I can smell it being delivered to the engine.
- The only change I made while it was sitting there was to fix the fiddly plastic cable clamp the pins the starter cable to its anchor point at the heating tube with the cast metal version from Axel Gerstl which I would recommend to everyone (the plastic one has broken on me at least twice). It is possible that doing so slightly changed the amount of tension in the cable, however it is does not look particularly loose and it is already on the last pin on the starter side. Adding more tension here would be one easy thing to eliminate but I am not sure how to add more tension without having to drill another hole in the heating tube to move the anchor point slightly. I also have not been able to get a good angle to try to press the trigger manually from the back of the vehicle. This has been my primary suspect because the vehicle was starting perfectly when I parked it last autumn, with no issues with the distributor or anything. But research suggests that the only role the cable/lever plays is in firing the starter motor, which is firing. So perhaps I should eliminate this as well?
- Pulling the lever with and without the ignition turned on produces the same sound / result. The starter motor is clearly firing, and cranking the engine, but the engine is not igniting.
- Model
- 126
- Year
- 1974
