S
Stu R
Right I have noticed today that my HGT is blowing warm air through the vents even when the heater is set to Lo(w). Now the temperature of the engine seems to fine with the needle only going to half way but to be honest, that is a little high for my car. My needle is usually one line.
On first start, the heater seem to work as normal, goes to the temp set and blows on full if set to Auto and Lo(w). When the temperature of the car get to normal then this changes. The heat coming out of the heaters is warm going on hot and the blowers slow down on auto to say if the temperature was set to 24 or 26.
Could any one shed any light on it?
big problem is that I'm the sort of person to av the windows down with a t-shirt on even if it was snowing, so with the weather getting warmer (hopefully
) then I'm really gone be sweaty
Thanks in advance
EDIT:
forgot to say, the temperature in the car doesn't alter that much with the climate (air con) on or off.
Thanks in advance
EDIT:
