Starting is most likely a dirty throttle body and MAP sensor. Both should clean up. The crankcase breather deposits oil vapou into the inlet manifold. I bet its now swimming in oil doil.. Reove the throttle body and MAF and clean the manifold. THe MAF may well also be the poor running at speed. It was on ours. But coild pack or plugs and leads might be a problem. I find the Pnada likes new plugs rather frequently or it starts complaining. Once a year at least is best. If this does not do the trick then you need to consider injectors. Its a job I have never tackled, but others report its not too hard. Take care removing the air box to tease it off, they are brittle.
