masterpatfx
- Joined
- Oct 30, 2017
- Messages
- 19
- Points
- 7
Hi! So my Fiat Punto Mk2 1.2L 8v (2002) is leaking coolant from above the oil filter, as shown in the photos. It seems to be coming from a threaded hole somehow, just above the filter and next to the water pump (which has the orange sealer).
The water pump and thermostat have just been replaced, and its not the hoses. I'm pretty sure its from that threaded hole in the engine block as there is no moisture above it or behind it. The water pump sealer is dry as well.
Can anyone tell me what this hole is please? I thought of inserting an appropriate sized bolt with a copper washer into it to seal it. What do you guys think?
Thanks a lot!
Thanks a lot!
