Technical Help code P0201
lifes a bitch
I hope someone can share some light on this problem code P0201 has come up and reads Injector Circuit open cylinder 1. Does anyone know how to fix this fault ? car starts and runs fine but eml is staying on.
is injector making noise or is there any build up of carbon around injector
The engine is running rough I have bought new injector for cylinder 1 new EGR valve new turbocharger and still have engine management light on and anti pollution on display . I've put diagnostic on it again its now showing cylinders 1, 4 , and 2 open surely they havent all gone , but I've changed no 1 and its still coming up as open really dont know what to try next Any suggestions !!!!
Do you mean the wiring that goes to the injectors ? What do I need to check the wiring :confused::confused:
For those reading this it turned out to be No 1 injector . I thought I had changed No 1 injector but changed No 4 instead . The sequence on my vehicle is from left to right . No 1 being on the left and No 4 nearest clutch.
Runs brilliant now
