Technical  Help! Clutch pedal
Du5980
My daughters 1998 1.9TD Scudo has a clutch pedal that is in no other words flappy! it had a clutch change by a garage but the problem never resolved of having to stamp very hard on the clutch to change gear, it doesn't come back up to level with the brake pedal either. Having had a look online and at the pedal there seems to be a spring attached to help it return to the correct position. Does anyone know where I can get one. I can not find one online nor in the car dismantlers I rang.
Any help much appreciated
Thanks in advance
Also, you could try a selection of breakers via the 1stchoice site. They take your description and e-mail address, and forward the details to breakers who are on their list, who then reply to you direct. I assume that 1stchoice get some commission. I have used them before with good result.
You could also look on eBay for people breaking vans, or even ask a taxi driver!
