'HELP' CAR WONT START 'HELP'
P
Paul Maks
My 98SX 1.6 with 42000 on the clock will not start today. The engine is trying to start but it just wont?? What is the problem!! Any ideas?!
Battery is fine, only 1 month old, all electrics work etc...
Paul Maks
Right, the engine is turning over ok I assume?
Is it trying to fire but won't keep going or is it just cranking and cranking with nothing else happening?
Re: Re: 'HELP' CAR WONT START 'HELP'
Thanks Tom, the car appears to be trying to start but just wont - wots wrong? I only got it last month????
Thanks Tom
Re: Re: Re: 'HELP' CAR WONT START 'HELP'
First off check there is no water or oil sitting around the spark plugs, my 1.6 seems to collect oil around a couple of the plugs.
Second, make sure the fuel cutoff is not off. Under passenger seat, black box with rubber top. Press the rubber bit.
Re: Re: Re: Re: 'HELP' CAR WONT START 'HELP'
Would the fuel cuttoff turn itself off?? I aint touched anything. Working great last night - and this morning nothing??!
Re: Re: Re: Re: Re: 'HELP' CAR WONT START 'HELP'
If you bang the seat hard enough back it can pop the cutoff... i've done it :)
Still not starting?
Re: Re: Re: Re: Re: Re: 'HELP' CAR WONT START 'HELP'
No it is just turning and turning, but not starting!! I have so little clues about this!
Tom, for the last 2 weeks, when starting from cold, the car sounds like a rattle snake hissing when you turn it over, you dont hear this when starting from hot?? Is this linked in any way??
Paul Maks
Re: Re: Re: Re: Re: Re: Re: 'HELP' CAR WONT START 'HELP'
Tom, after turning and turning, it started with a lot of spluttering, i pressed the little cut off switch as suggested??!
This doesnet help though, dont think that was the problem, never use the passanger seat.
Re: Re: Re: Re: Re: Re: Re: Re: 'HELP' CAR WONT START 'HELP'
some one might have syphoned your petrol? i know it sounds silly, but check,
The noise when starting from cold is the choke cutting in to keep the engine running, nowt to worry about.
Mine did that, would not start until you held the pedal down and cranked for ages, have NO idea why but its only done it once.
J
1
775
Dark Lurker
3
7K
Steve
S
3
1K
Tommy K
T
W
922
wakka
W
C
7K
Carroll
C
