Help car electric problem
E
eren
Now i dont know what is wrong with my bravo, but if i quickly go from off to on n then start it, like in 1 movement, sumtimes if i do it reely quickly, all the electrics fail, everything goes off....like immobiliser. i can turm the key all the way with no problem, but there is no electrics so wont start or nothing...the only way me n my m8 worked out how 2 fix it was, we slammed the door shut, n just as it slams, all the lights gpo on 4 a second, n just as it slams i quickly start the car n then its all sweet as a nut, i have 2 leave it running 4 about 15mins n then it will start again when i turm the car off.....HELP!!!
By the door, you are talking about the driver side door ???
If so, sounds like your fuse dash looses contact, remove the lid right of the steering wheel and check all the fuses and the connectors that are on the back. Also check the fuses under the bonnet.
Measure the battery voltage, and try turning it on slowly, it also may be that your lock is playing up.
Members Site
Its all good i sorted it out 2day, seems like 1 of the battery terminals wasnt connected properly, it was sittin ontop loose...so the reason it would all go out was because the battery wasnt connected lol...so when my m8 used 2 slam the passenger door, the terminal would touch 4 a second coz of the shaking of the car and id get a chance 2 start it....The idiots at halfords tested my barrery only a few days before, looks like they forgot2attach the wires back on properly...IDIOTS!!
C
2
808
K
C
7K
Carroll
C
W
914
wakka
W
T
1
794
Joseph
J
