Help! Airbox screw stuck!
H
Hellraiser
Typical. I finally get me a K&N kit, then I can't get me bloody airbox off! What has happened is the screw has seized in the brass insert, net result being that when I try to undo the screw the insert rotates inside the plastic the other end and it don't come out!
Short of hacksawing it, anyone got any ideas?
Hellraiser........>
I'm sure someone said if you remove the arch liner, you can get at said bolt from underneath, or at least stop it from turning...
I ended up leaving the bottom half of the box in there, and cutting off the bolts...:(
Daz
Yep, I feel a hacksaw moment coming on. Gave up for tonight, then as I put the filter in the boot realised I had a flat tyre too :(
Hellraiser.........>
If your putting an induction kit in there, just bust it out....
if you want to take it out properly so that it can always be put back in it's a wheel off job - arch liner off then it just slips out the bottom. much easier than forcing the thing out through the top!
