hi, that was quick. the car is a stillo 2002 with a 1600 16 valve engine. it has the electric moter assisted steering and it has the fault codes. i will read them and post again. thanks for a quick reply
hi again. read the codes using an autel maxi scan and the following was evident. u1600 u1700 u1702 p0530 p0571. i then cleared the codes started her up and again read the codes. now all the codes are clear, it says no codes found but on the dash it says power steering fault and power steering warning light failure
