Technical  hello all, and question about detached window
elmend
Hi, i'm Mike, i have a Tipo 94 1.6 and a lot of newbie questions!.
The driver's window gets out of rail when it goes up, it is detached from the lifting mechanism only on the top of the glass, and it derails as it goes up so i have to keep it pushed back into the rails while it's going up.
Is this easy to fix?, provided i manage to remove the door trim panel.
Would i need to buy some replacement part or is it just reattaching the window to the mechanism?
yer its quit a common problem with topo's and tempra's theres plastic clips with go into runer wich attach to the glass thay brack very easy its not to bad a job to do but be vear curfull you dont brack the window giude
