Technical  Heating gremlins
Veedunk
Hi all, new member here so bear with me.....
Just bought a 2005 Ulysse Eleganza 2.0 JTD, when I drove it home I noticed a few things
Temp gauge didn't go above 70c
No warm or hot air in the car
No blower in the front but blower working in the rear
Couldn't get air con very cold
Headlights switch on when they should be off.
Since then I've fitted a new pollen filter and air filter, drained the coolant and flushed through, re-filled,and fitted a new thermostat. The old stat seemed to work ok when I tested it in the saucepan, but now the temp guage reads 85c.
I've taken the blower out and tested that it works with a direct 12v feed and all ok, but I don't seem to be getting power to the blower. I checked the big fuses in the fuse box next to the engine and they all seem ok.
I still can't get any hot air into the car, cold air seems ok though through the rear vents.
I haven't even looked at the lights problem yet:confused:
If anyone has got any help that would be greatly appreciated, I'm a bit of a novice so don't get too technical!
Many thanks in advance,
