Hi, first time. I am helping a friend. the blower has stopped working completely. I have read this and others and they all talk of the 'resistor pack'. My question is: the model we have has the electronic climate control setup. The place where the resistor pack should be has a blank covering the hole - done in the factory, not afterwards. Do this model have a resistor pack? If it does, where is it? Is there anything else that could stop the blower working?
Thanks.
Thanks.
Sorry used wrong name, my reply was to PickwickDear Thomaz
Good morning. Thank you for the information. We have just managed to remove the blower from the housing - no easy task!!!! with the steering column and clutch pedal. In the end we removed the black plastic housing from the motor while still in the hole.
With climate control model you have the solid state resister unit attached to the black plastic motor housing with the 3 connectors. Is there any way checking the resistor unit? The motor works great powered direct to 12v.
Thanks.
