The girlfriends heater on her 500 is playing silly buggers, when turning the heater on to hot it blasts out cold air and to fix this you have to perform the reset by holding the two buttons together till the numbers turn to zero, but this doesn't always work and continues to blast out cold air, i have found that if the reset doesn't work you turn the temperature down to low and it will then start to blast out hot air.
does anyone have any experience on this issue as i'd like to get it fixed for her instead of it being backwards.
