HI
I have read several heater issues here on the forum, but can't find one similar to my issue.
There is no heat in the cabin from the heater. I need to figure out if it is just a cable issue.
The fan is working OK
The engine temp seems normal at half way on dial.
I can feel hot water through the pipe going into and out of the cabin in the engine bay.
When I turn the heat knob from cold to hot, I can hear something moving, up to half way (when the red on the dial shows). Then nothing.
So am I right in assuming it is a lose cable, not opening heater flaps? Or could there be another issue as there appears to be hot water in the pipes both sides of the internal radiator.
