Technical Headlight normal beam issue
cecfc
Rutland
Hi All,
If anyone can advise that would be much appreciated. Thanks
I have a 1968 Fiat 500L. When Headlights are on normal beam the passenger right side does not beam and the left does, but on full beam both headlights display.
Can you think of any reason why the normal beam does not Beam on the passenger right side.
FYI - I have swopped the bulbs around and the same issue occurs. So, not a bulb issue.
Could it be the wand on the steering wheel, an earth of some other issue?
Model
Fiat 500L
Year
1968
Hi All,
Sounds like a wiring issue on the live side to right hand plug, not earth as lights otherwise working fine.
Can you just probe back from dip beam plug on drivers side with a multimeter?
Wiring could be corroded at connections.
