Technical Headlight angle adjustment
Midlands
Hello Qubans, My headlights seem to be angled low, even when set to their highest setting. I'm trying to figure out where the adjustment screws are but I haven't found any information about the qubo/fiorino headlight unit specifically.
Is it the two bolts sticking out the back near the top of the unit?
Thanks for any help :)
Mine were the same so I took it to an MOT station and they adjusted them for me.
Yes. The ones located outside towards the car(deeper inside) adjust Up/Down while the other bolts located towards the middle of the car(easily accessible) adjust Left/Right. They are 6mm hex tipped bolts if I remember correctly so 6mm wrench or socket is all you need.
Hi
I had the same issue...Miles to low
When it came to the mot they adjusted them higher, but when i used a different mot station a year after they adjusted them back down again and i have to keep them on the high setting for them to be any good
I do carry a lot of gear at all times so it wasn't that the van was empty on the first visit and loaded on the second
I still think they are to low though
Luigi
