We all know that our Bravo's that don't have xenon,have bad headlights, short beams especially, so hid is the best solution. Do our headlights have an adjustment screw's somewhere, to lift the beam up, or something like that?
That's handy , thanks.
I think mine need to come up a notch![]()
Thanks for this information. I have one question: what is the height of the line AC-AC? I think my headlight beam is too low. So I'll adjust the horizontal position. Therefor I need to know the height of AC-AC. Thanks!look this: http://forum.fiat-bg.org/download.php?id=35773
now i have a perfect lights
Read the guide again, you don't need the AC-AC height, there is no such number.
As the guide says, AC-AC should be 10cm below HC-HC. And HC-HC can easily be measured (as explained there).
It's normal if your headlight beam seems low, it's because it's crapUpgrade to xenon as soon as you can.
Or is HC-HC a given line that never changes? Let me think again... HC-HC is a 'virtual line' exactly as high as the ground clearance of the center of my headlights? So AC-AC has to be 10 centimers lower as the center of my headlights.
ThanksExactly. HC never changes, is the height from ground to the center of your headlights, marked on a wall 10 meters in front of the car.
Once you have HC marked, just adjust AC to be 10cm below it.
I don't know if I need to. I only think my beam is too low. I already visited the dealer, the've tested the beam and said that everything is perfect. But in my opinion the beam is too low...I am surprised however that you need to manually level bi-xenons.
Indeed, the levelling is automatic. It's always levelling to a certain height. But you can adjust that "certain height".Bi-xenons level themselves, I didn't even know manual adjustment is allowed...
I have the bi-xenon lights for sure. And i paid forSomething must be wrong, or you have regular headlights (non-xenon).
the standard xenons are impossible to adjust manually, they will always adjust their height automatically no matter what you do with the screws.
Exactly! With the screws you can adjust the starting position. I've checked the height of my beam with an other car and I think the beam is right. It seems to be at the same height as an other car.that is not true
the fabric xenons don't have adjustment from the driver seat
but the are adjustable by the screws
the headlights must have correct staring position, and then the self-leveling system will work
