LanciaMad Established member Joined May 13, 2005 Messages 1,176 Points 363 Location Toon Oct 23, 2009 #1 How important is it to skim the head when changing the gasket? Anyone done it without skimming?
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,863 Location Lake District....Moist Oct 23, 2009 #2 To do the job properly, skim it. It will fail again quickly if you don't. Cheers SPD
Dan SX 01 Patron member Joined Jan 13, 2009 Messages 85 Points 21 Location Pershore Oct 23, 2009 #3 What about if its not failed and changing it as a precaution?
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,863 Location Lake District....Moist Oct 23, 2009 #4 Dan SX 01 said: What about if its not failed and changing it as a precaution? Click to expand... Still skim it. Very false economy not to, and gives a perfect mating face, which is, of course entirely different to a 'cum face'. Cheers SPD
Dan SX 01 Patron member Joined Jan 13, 2009 Messages 85 Points 21 Location Pershore Oct 23, 2009 #5 Ok, thanks
richydraper Prominent member Written 10+ guides Joined Nov 30, 2006 Messages 2,780 Points 692 Location Coventry Oct 23, 2009 #6 always skim the head if you have the engine out skim the block too
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,561 Location Liverpool Oct 23, 2009 #7 No point in skimming the block. Just make sure it's as clean as clean can be.
M mjinks New member Joined Oct 25, 2009 Messages 2 Points 1 Oct 25, 2009 #8 Always the best option is to have the head skimmed, just had one done for £30 at a local engineering place
K KingKongsProtege New member Joined May 10, 2009 Messages 1 Points 0 Location Hull Oct 29, 2009 #9 how much should be skimmed off the head?
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,722 Points 3,336 Location Manchester Oct 29, 2009 #10 the min amount to make it flat
FIREsporting Sei Sporting abarth Written a guide Joined Mar 4, 2007 Messages 1,307 Points 198 Location Kent Oct 29, 2009 #11 LanciaMad said: How important is it to skim the head when changing the gasket? Anyone done it without skimming? Click to expand... Skimming the head will make it perfectly flat again or near enough and ensure that there is a tight fit between the new gasket and the head.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,863 Location Lake District....Moist Oct 29, 2009 #12 Your engineering shop wiill take a wee bit at a time off the head until they get to a flat surface. Cheers SPD
OP OP LanciaMad Established member Joined May 13, 2005 Messages 1,176 Points 363 Location Toon Dec 28, 2009 #13 just for the record i didnt get the head skimmed, just cleaned it as much as i could. Cars fine so far, will let yous know when it next goes like.
OP OP LanciaMad Established member Joined May 13, 2005 Messages 1,176 Points 363 Location Toon Jun 16, 2010 #14 6 months on and still going strong
C clock34 Prominent member Parked in the garage Joined Oct 20, 2007 Messages 4,936 Points 744 Jun 17, 2010 #15 i never skimmed mine think its only neccisary if it overheats and warps slightly?? i could be wrong and when i do my next engine i will skim it so i ensure its reliability
